1963-67 seats - NCRS Discussion Boards
1963-67 seats
  • Jack J.
    • July 31, 2000
    • 640
    1963-67 seats
    If possible, is there a trick to remove both slide adjusments from the seat frame? Want to degrease, media blast and paint. Thanks in advance, Jack J.
  • Gene M.
    • April 1, 1985
    • 4232
    Re: 1963-67 seats
    Unscrew the bolts. They are a plated finish. Blast and paint would not be a good attack unless one disassembles them completely. Sand does not work well in a grease lubricated assembly with the slide rolling action.
    • Jack J.
      • July 31, 2000
      • 640
      Re: 1963-67 seats
      Gene, thanks for the reply but how do you get the notched slider out of the tubular seat cushion frame? JJ
      • Gerard F.
        • June 30, 2004
        • 3806
        Re: 1963-67 seats
        Jack,
        There are just 4 phillips head bolts which hold the sliders to the seat frame.
        Below are some photos from my 67. The last one is using the sliders for a template for the carpets cuts (1967 only).
        The tracks for a 67 have a dark gray primer, clean them up and put plenty of grease inside.
        Jerry Fuccillo
        Jerry Fuccillo
        • Harry S.
          • July 31, 2002
          • 5330
          Re: 1963-67 seats
          Jack, if the 64 is like the 63 they do not come out as they are welded in. What I did with the 63 was.... I bought 8 cans of CRC brake cleaner in the red rattle cans. After I had everything off the seats I used 5 cans to spray and clean the slides to remove all the junk and grease. After the seats were medial blasted I used 3 cans to remove the remaining media and any grease that I may have missed on the first pass. I then primed and painted the frames. When that was completed I rebuilt the seats, foam, vinyl, etc. The very last thing I did is grease the sliders. This is to avoid getty any new grease on you new foam and vinyl or leather. They have been working fine for 10 years.
          Good luck
          • Jack J.
            • July 31, 2000
            • 640
            Re: 1963-67 seats
            Thank you Harry, that's the answer I was looking for since my car is a 64.
            • Stewart L.
              • March 1, 1980
              • 355
              Re: 1963-67 seats
              Corvette America has a good video on there web site that shows the disassembly and restoration of the seat frames.
              • Jack J.
                • July 31, 2000
                • 640
                Re: 1963-67 seats
                Thank you Stewart
