My 1964 L76 327/365 with the 2818 carb has only one throttle return spring. If I remove this spring, the throttle will stick wide open. On some other Holleys (Model 3310 for example) there is a spring on the throttle shaft that snap the throttle shut even on a bench. My 2818 does not have this and it seems a little unnerving relying on one return spring. I have seen double springs (smaller spring inside the larger) on some GM applications but mine does not have this. Any comments appreciated.
L76 Holley 2818 Throttle Return Spring
Re: L76 Holley 2818 Throttle Return Spring
Mike,
The double springs are typically a "band aid" fix for an improperly adjusted or gunked up carburetor. The single spring is more than adequate to return the throttle if the carb is properly maintained.Leif
Top Flight 2017 Lone Star Regional- Top
