63 Center Hanger Bracket Straps - NCRS Discussion Boards
  • Thomas S.
    • February 7, 2016
    • 618
    I have a original 2-1/2" exhaust with center support bracket that needs to have the straps replaced. The straps are basically gone so I don't know how long they should be. I also have a fully intact NOS 2" center support bracket with straps. The question is whether there was only one length strap used for both 2" and 2-1/2" systems as well as whether the centerline of the rivets was also the same.
    The AIM only shows a single set of p/n's for the bracket and hardware, which is interesting because the actual support bracket itself would be different.
    67 427/400 Lynndale Blue Corvette https://online.flippingbook.com/view/750924569
    • 6958
    Re: 63 Center Hanger Bracket Straps
    Tom, I an pretty sure that one of the corvette vendors makes a repair kit for the center hanger.
    • Harry S.
      • July 31, 2002
      • 5345
      I believe they are both the same.
      https://www.paragoncorvette.com/p-36...anger-kit.aspx
      10% off if you tell them you belong to NCRS
      • Don S.
        Infrequent User
        • August 31, 2000
        • 25
        Just sand blasted my 63, 340 HP, 2 1/2" hanger. Rubber straps are 3 1/4" long. Would be interested if the 2" ones are the same length.
