Fuel injection electrical anti siphon valve connection - NCRS Discussion Boards
  • Doug Y.
    • January 15, 2009
    • 62
    I am just installing my rebuilt transistor ignition distributor to my fuel car. Where do I attach the hot wire from the anti siphon valve setup that I had connected to the resistor now that the resistor is not needed? Thanks for your help dcy
  • Don H.
    • December 1, 1981
    • 1487
    Re: Fuel injection electrical anti siphon valve connection
    Doug, Any 12 volt source that is switched on and off by the ignition switch. Mine are attached to the ballast resistor which you have apparently eliminated. You did not say what year your car is so I can't be more specific. Good luck, Don H.
    • Doug Y.
      • January 15, 2009
      • 62
      Hi Don thanks for reply my car has a 1965 fuel injection unit and I am installing a TI distributor. I had a points style
      distributor to start engine tuning and now am switching to TI which does not use the ballast resistor. I have since learned that
      I can install the hot wire in the cluster used for TI connections. Many thanks Doug Young.
      • Patrick S.
        • January 1, 1988
        • 209
        Install a hidden toggle switch in the power source line as a security measure.
        • Doug Y.
          • January 15, 2009
          • 62
          Great idea Patrick I shall do so Thanks Doug Y
