Power Steering Pump Leak - NCRS Discussion Boards
  • Bill B.
    • June 30, 1999
    • 182
    The reservoir on my 65 327/300 is leaking and it appears to be the O ring that seals the can. I've just ordered a kit and my question is: once I've removed the pump can I just take the pump out of the can to replace the seal and leave the pulley in place on the shaft? The pump is new but I can't return it because I bought from an individual and not the rebuilder. I don't see any reason I can't do it that way but I wanted to ask and get a response from folks who have rebuilt pumps before.
    • 6940
    Re: Power Steering Pump Leak
    Bill, yes you can replace the o-ring seals with out removing the pulley.
      • 43210
      Edward and Bill------
      Yes. However, inspect the reservoir and the pump body carefully to make sure the leak problem "doesn't go deeper" than the o-ring. If this is a previously rebuilt pump there's always the chance that there was some distortion of the reservoir or damage to the pump body casting, itself.
      • Bill B.
        • June 30, 1999
        • 182
        Thank you for the feedback and advice, Edward and Joe.
