64 differential fill plug gasket or not? - NCRS Discussion Boards
  • John F.
    • March 23, 2008
    • 2423
    I decided to pump out as much fluid as I could and refresh with new. Castrol sells a differential fluid with posi additive. Is there supposed to be a gasket? or just the posi tag?
    • 43285
    Re: 64 differential fill plug gasket or not?
    John------
    1964 was the last year to use a straight thread plug and requires a gasket. I believe the original gasket was made of leather. 1965 and later use a tapered thread plug and require no gasket.
    By the way, the above assumes that your carrier has the original cover and not a later 65-79 style cover installed as a SERVICE replacement. If it has the later cover, it will require the later tapered thread plug.
    • John F.
      • March 23, 2008
      • 2423
      It is the straight thread plug. Thanks Joe!
      • Dan H.
        • July 31, 1977
        • 1372
        John, be sure to use thread sealant also for a nice dry plug area.
        Dan
        1964 Red FI Coupe, DUNTOV '09
        • Gary R.
          • April 1, 1989
          • 1806
          Those plugs are machine threads, thus the need for the gasket. By 65 they went to the 3/4 npt as Joe mentioned. Some guys use an "o" ring to seal between the plug and housing. The gasket will work though.
          • John F.
            • March 23, 2008
            • 2423
            From outside in, I went plug, posi tag, "O" ring. I also ordered a gasket if I need one.
