1968 P01 Bright Metal Wheel Cover Restore - NCRS Discussion Boards
  • Larry E.
    • 1700
    Have a set of 1968 P01 Bright Metal Wheel Covers with small scratches on outer rim. Is there anybody
    out there that restores these?? Thanks in advance--Larry
    Larry
    LT1 in a 1LE -- One of 134
    • 6958
    Re: 1968 P01 Bright Metal Wheel Cover Restore
    Larry, if your dealing with curb rash it may be difficult to restore, minor scratches can be removed, There maybe someone in your area that restores stainless ??
    • Terry B.
      • August 31, 1999
      • 607
      Larry, there are 3 separate parts to the PO-1 and PO-2 hubcaps. For a lack of better terminology I will call the 3 parts the base, the middle and the cap. It is the the middle that gives the PO-1 it's distinction from the PO-2. What you can do for your restoration is find a good set of PO-2's on ebay and switch out the bases with your curb rash PO-1 set. If the black paint on the PO-2 bases need refreshing, get some gloss enamel and a good small brush and repaint them. If you need new caps, Paragon sells them. You can do your own restoration and they will look great.
      Terry Buchanan
      Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
      Corvettes Owned:
      1977 Coupe
      1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
      2003 Electron Blue Coupe
      2019 Torch Red Grand Sport Coupe
      • Ron G.
        • December 1, 1984
        • 866
        "SOLID LIFTERS MATTER"
        • Terry B.
          • August 31, 1999
          • 607
          Hi Ron,
          If you can find the PO-1's and the fins are in good shape, you can make everything else look good. Also, the PO-1 middle or fins top base for the cap is just about an eighth of an inch larger than the PO-2 cap base. In the wood working field that would be called a reveal and gives it more visual lines. I think it gives the area a little more character.
          Terry Buchanan
          Corvettes Owned:
          1977 Coupe
