There is an engine vibration when driving my 365hp 64 as the rpm approaches 3500-4000 rpm. It almost sounds and feels like a thrashing machine. I did not run the rpm any higher as not to damage the engine. This is the first time the engine has been up to that rpm since it was rebuilt. About 250 miles on the engine.
not balanced as a unit. The harmonic balancer is the original. I am not sure what the symptoms are of a harmonic balancer problem. How can I determine which component could be the source of the problem? Thanks for any help. Rod
