Fuel pump ID - NCRS Discussion Boards
Fuel pump ID
  • Harmon C.
    • August 31, 1994
    • 3228
    Fuel pump ID
    I have a A/C fuel pump # 212 40658 stamped on the flange wil it work on a 71 LT1?
    Lyle
    • 43284
    Re: Fuel pump ID
    Lyle-----
    The AC 40658 fuel pump is the pump originally used on 1968-69 Corvettes with small block. It was only available in GM SERVICE for a very short time but was available through AC Delco for a longer period. It was replaced for GM SERVICE by the AC 40709. The 40709 is the pump used in PRODUCTION for 1970-71 LT-1 (and SERVICE for 1972 LT-1). The primary difference between the 40658 and the 40709 is the inlet chamber. The 40658 has a short inlet chamber; the 40709 has a long inlet chamber. We know the 40709 is compatible with applications originally using the 40658 because GM said so. We don't know, for sure, if the 40658 is forward compatible with applications originally using the 40709. However, I believe it is.
    • Harmon C.
      • August 31, 1994
      • 3228
      Re: Fuel pump ID
      Thanks Joe I know the inlet and outlet position is correct.
      Lyle
      • David L.
        • July 31, 1980
        • 3310
        Re: Fuel pump ID
        Lyle,
        AC 40658 = GM # 6417337
        AC 40709 = GM # 6470110
        As per Chevrolet Parts History GM # 6417337 was discontinued in Aug. 1971 and replaced by GM # 6470110 which was discontinued in Aug. 1985.
        Back in Jan. 1994 I bought 4 unboxed NOS 40658 fuel pumps (all stamped "40658) at the Cypress Gardens swap meet....all 4 for $20. Even though all 4 were NOS the coatings on the top part of each one of them had deteriorated (oxidation?) so that is why they were cheap.
        When I bought my 1966 Corvette in 1979 the fuel pump on the non-original engine was stamped "DI 40658" where "DI" = April 1969.
        Dave
          • 43284
          Re: Fuel pump ID
          Lyle------
          Yes, the inlet and outlet position is correct. The outlet position is, of course, critical if the original fuel line is to be used. The inlet position might not be exactly the same but it will work with no problem. However, the inlet nipple is higher on the 40658 due to the short inlet valve chamber.
          • Ron G.
            • December 1, 1984
            • 866
            Re: Fuel pump ID
            The inlet at the bottom of the pump faces towards the left rear wheel. The later over the counter #40709 inlet faces towards the right rear wheel. It will still work just fine. - Ron
            "SOLID LIFTERS MATTER"
