amp gauge - NCRS Discussion Boards
amp gauge
  • Mel S.
    • August 31, 1992
    • 264
    amp gauge
    I have a 66. i was working on the horn rely and it sparked when one of the hot leads grounded out. Dumb me for not disconnecting the battery. Now the amp meter is consistently discharging but when i check the battery it is charging 14.2 volts. Is there a fuse in line that i blew? Did i burn out the amp meter?
    Mel
  • Danny P.
    • Today
    Re: amp gauge
    Check if your horn works you could of blown a fuseable link on the relay harness or starter harness
    • Mel S.
      • August 31, 1992
      • 264
      Re: amp gauge
      The horn works along will all of the other electrical in or on the car
      Mel
      • Danny P.
        • Today
        Re: amp gauge
        Check voltage behind the amp meter at both rear post you should get the same voltage you get at the battery 14.2 if you do the amp meter is done
        • Richard G.
          • July 31, 1984
          • 1718
          Re: amp gauge
          In theory it is possible to run the shorted current through the amp meter in the situation you described.
          The gauge is really a voltage meter not a amp gauge as listed but that's another story.
          Another test it to go from one amp gauge terminal to the other with the measuring meter set to 5V or less.
          With the motor off:
          With the low beam headlights on it should read a nominal .16V
          With the high beam headlights on it should read a nominal .2V
          If the readings are anywhere close to these readings the circuit is good.
          Rick
          • Mel S.
            • August 31, 1992
            • 264
            Re: amp gauge
            Thanks - i will give it a try. You are right it is a volt meter - my error
            • Richard G.
              • July 31, 1984
              • 1718
              Re: amp gauge
              If the voltages (lead to lead) are somewhere close to the above readings (nominal) it is likely your Amp gauge is defective.
              It is more important the readings change when the load changes than what the exact reading is.
              The last test I use is a used 1.5 V battery attached to the leads of the amp gauge.
              1.5 volts will peg the gauge that's the reason a used battery works better.
              Polarity will not matter it just moves the gauge to the - or + side of the gauge.
              Best of luck.
              Rick
