1966 Manual brakes - Air in brake system after M/C replacement and highway driving - NCRS Discussion Boards
  • William L.
    • April 1, 2002
    • 5
    I had the m/c rebuilt and system bled and filled with DOT3. I had a firm brake pedal for days running town on surface roads. The first time I took on the highway(15 miles) the brakes went to the floor on the exit ramp. I'm able to stop the car using a lot of runway and the last inch or two of pedal prior to hitting the floor. If I pump the brake rapidly the pedal firms up for a second then quickly loses firmness.
    This the 3 time this has occurred: First time I lost the pedal, the fluid was a little low after a firm stop. I filled it up, but never got the pedal back. So I had the system bled and filled. Firm pedal until I drove on the highway and lost my pedal on the exit ramp. Since the bleeding did not fix the issue, I had a new m/c installed. Same thing... Firm pedal until freeway drive. Lost the brakes on freeway exit ramp. I've done a lot of research on this site and sounds like rotor runout, but I haven't changed the rotors or calipers or anything in quite awhile. The car has Repo KOs. Does this impact anything? The gentleman who has done the last two m/c installatons is dubious about the rotor runout, but now will not return my calls. Am I on the right track? Any other possible solutions? No leaking has been seen at the M/C, calipers or brake hoses.
    • 43259
    Re: 1966 Manual brakes - Air in brake system after M/C replacement and highway drivin
    William------
    The first thing I would do is to measure the rotor runout, front and rear. This is not very difficult to do.
    • William L.
      • April 1, 2002
      • 5
      Thanks, I'll get a dial indicator and give it a whirl.
      • Danny P.
        • Today
        i would open all bleeders and let it gravity bleed for a while to make sure all the air is out and no trap air anywhere at the same time check the rotor run out
          • 15706
          I had the m/c rebuilt...
          Pedal goes to the floor with no evidence of leakage can be an internal leak/failure of the master cylinder. Check under the IP for fluid leakage from the end of the m/c, and discuss the situation with whoever rebuilt it.
          • Mel S.
            • August 31, 1992
            • 264
            Check the pads for wear. I had a problem years ago with loosing the brake pedal like you. Putting new pad on did the trick for me.
            Mel
            • William L.
              • April 1, 2002
              • 5
              Thanks for responding. I'm trying to learn and do not mean any disrespect when I ask why would having the bleeders open impact the measurement the rotor runout? Thanks for your patience.
              • William L.
                • April 1, 2002
                • 5
                Duke,
                I could not see any evidence of leaking outside. I will follow your direction, but am unsure what the 'IP' is that you are referring. I'm sure its very simple, but I don't know what you're referring to. Thanks.
                • William L.
                  • April 1, 2002
                  • 5
                  Interesting. I will take a look. Thanks for your reply.
                  • Mark E.
                    • April 1, 1993
                    • 4604
                    Instrument Panel
                    Mark Edmondson
                    Dallas, Texas
                    Texas Chapter
                    • Mark E.
                      • April 1, 1993
                      • 4604
                      They don't. I believe Danny is merely suggesting you do both- not necessarily at the same time.
                      Mark Edmondson
                      Dallas, Texas
                      Texas Chapter
