C2 door won't open help - NCRS Discussion Boards
  • Keith W.
    • June 30, 1998
    • 375
    So I've removed the door panel and removed the metal plate to get some access to the door mechanism and tried everything to find how do you alllow the star to free wheel - as always any help would be great
  • John L.
    • February 20, 2009
    • 186
    Re: C2 door won't open help
    Keith
    The latch looks functional from limited picture - looks to be in locked position (obviously, lower rod may need to be disconnected if lock cylinder not functional and inside release has been disconected ) then push upper plate to open door
    Is the body off the frame where the latch/door has become jammed against the striker?
    • Harry S.
      • July 31, 2002
      • 5330
      Keith, remove the latch from the door and ensure it works. If it does the problem is most likely the rod from the door handle. I have seen them wear 3/8 of the metal away from use. If that is the case just replace the door handle button.
      • Keith W.
        • June 30, 1998
        • 375
