1973 air cleaner to hood adapter ring - NCRS Discussion Boards
  • Mike E.
    • February 28, 1975
    • 5148
    How do you tell the difference between the one for a small block versus the big block one? Thanks
  • Jimmy P.
    • June 24, 2014
    • 1696
    Re: 1973 air cleaner to hood adapter ring
    Mike,
    The BB flange offset is elliptical in shape, while the SB ring flange offset is concentric. The arrows in the first photo below highlight the narrow offset on one end. The center is an original 73-74 454 ring. The last photo is an original L48/L82 ring to show the difference.
    Hope this helps!
    Jimmy
    1973 Convertible
    L48,M20,N40
    Mille Miglia Red/Oxblood
    • Sal C.
      • December 1, 1984
      • 430
      The 454 ring is shorter than the 350 as the carb is closer to the hood
      • Russ S.
        • April 30, 1982
        • 2163
        Great info Sal! I have had a collection of 6-8 of these A/C for years and hadn't heard of the height difference before so I checked them and you are correct. The over-all height is about a 1/4 inch less on the BB and the effective height (from top of the air cleaner to the top of the ring) is about a half inch shorter on the BB.
        • Jimmy P.
          • June 24, 2014
          • 1696
          Russ,
          You saved me an email! I was just about to ask you to measure yours. This info will be great to point out in the revision. BTW, the first two photos in my thread above are from Russ....
          Sal,
          While we're on this sudject, why the elliptical shape on the 454 rings? Is the distributor mounted up closer to the carb, or is the BB mounted back a little further?
          Thanks!
          Jimmy
          1973 Convertible
          L48,M20,N40
          • Sal C.
            • December 1, 1984
            • 430
            I've seen a lot small block rings on big block cars over the years. They fit, but it squashes the hell out of the rubber seal.
            • Mike E.
              • February 28, 1975
              • 5148
              What is the height dimension on the metal part of the ring for a BB car? And what is the going price for a BB one?
              • Russ S.
                • April 30, 1982
                • 2163
                Overall height of the LS4 ring is 1.350 The OAH of the SB ring is 1.725 Going price approx. $250-300. unless you get lucky.
                • Mike E.
                  • February 28, 1975
                  • 5148
                  Thanks to you all for the helpful input.
                  • Tom R.
                    • June 30, 1993
                    • 4105
                    If you like that 73 tidbit, you'll love the revised 73/74 TIMJG that is chock full of data minutia these team members have saved up for years!
                    Tom Russo
                    78 SA NCRS 5 Star Bowtie
                    78 Pace Car L82 M21
                    00 MY/TR/Conv
                    • Gary C.
                      • April 1, 1998
                      • 380
                      Reviving on old post here but Terry in Perth is doing an NCRS resto on his 73 LS4 and cannot find a LS4 air cleaner flange for love nor money!
                      It is the one Jimmy describes in Post #2.
                      Any clues where he can obtain one?
                      Gary
                      Perth, West Australia
                      • Jimmy P.
                        • June 24, 2014
                        • 1696
                        Gary
                        Hi Gary,
                        Might want to check with Russ who posted above to see if still has any that he might part with. I'm sure he'll see this post. Every now and then one would show up on eBay but I haven't seen any for quite awhile. Just checked and there's someone selling the 454 seal and ring on there now for a lot of $$$$$. You could also check with David Sokolowski who advertises many parts for sale in the Driveline. Be specific with your request, not too many folks know about the differences.
                        Good luck
                        Jimmy
                        1973 Convertible
                        L48,M20,N40
                        • Sal C.
                          • December 1, 1984
                          • 430
                          • Mike E.
                            • February 28, 1975
                            • 5148
                            Gary,
                            Sent you an email on a source for one.
                            • Gary C.
                              • April 1, 1998
                              • 380
                              Thanks for your help Mike, we really appreciate it as old Corvettes parts are hard to get down under!
