What are the dimensions of the shifter locating gauge for adjustments?
Tags: None
- Top
Re: GuysWhat are the dimensions of the shifter locating cage for adjustments?
I believe the dimensions and a picture are in the Service Manual.Vice-Chairman (West), Michigan Chapter NCRS
Are you asking about the gauge plate that sets up the shifter alignment? If so it’s .625” to .628” defending on wear and age. It should fit with no clearance.- Top
Thanks Gene. Yes that's what I'm looking for. I have a service manual and saw that it should be 41/64" but what about the width? SM doesn't say anything.
Mike- Top
OK Gene now I think I understand. Its the WIDTH that is the 41/64" and the thickness doesn't matter. Thanks for clarifying for me.
Mike- Top
Needs to fit through the outer frame hole and allow the gates to "settle" against the gauge snuggly. Then adjust the rods.
Heres a shot of the hole.Attached Files- Top
Here is the instructions from Vette Products that gives the measurements to fabricate a gauge block to make the adjustments.
James- Top
Just a flat piece of metal slightly smaller than the rectangular hole inserted into it until it bottoms out on the opposite side of the bracket. You should manipulate the gates to insure its passing through both gates. The gates have a notch on them to accept the tool(at least the 68 3 & 4 speeds do). Your basically making sure both gates are parallel to the rectangular hole. You will need to make an L shaped tool if the trans is in the car which is the best way to align the gates and shift rods. Best preformed on a lift with dad in the car manipulating the shifter.
I tried to find the tool I made, no luck.- Top
The photo in post #8 shows the “window” the sheet metal gauge fits into as described in post #10.
And yes dad or grandson is a perfect helper........- Top
Here ya go Mike... I just cut up an old license plate to fit snug in the slot. Line up all the gates, push the guide in till it stops at the the othe end of the c bracket. You can bend it anywhich way you want. In or out of car. John
Attached Files- Top
