Purpose of small bracket above #2 spark plug? 1970 LS5 with AC - NCRS Discussion Boards
  • Mark E.
    • April 1, 1993
    • 4536
    What's the purpose of this small bracket above #2 spark plug and in front of the exhaust manifold?
    1970 LS5 with AC (compressor removed in this photo).
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
  • Rick N.
    • August 25, 2017
    • 141
    Re: Purpose of small bracket above #2 spark plug? 1970 LS5 with AC
    I don't see any picture.
    • Mark E.
      • April 1, 1993
      • 4536
      Trying again. I see the photo but no paper clip.
      Mark Edmondson
      Dallas, Texas
      Texas Chapter
      • Rick N.
        • August 25, 2017
        • 141
        That looks like an oil pressure gauge line bracket.
        It is supposed to be bolted to the cylinder head at cylinder #7.
        • Mark E.
          • April 1, 1993
          • 4536
          Thanks Rick. That bracket is missing on the left head.
          I wonder if the cylinder heads were swapped left/right during overhaul...
          Mark Edmondson
          Dallas, Texas
          Texas Chapter
          • Mike E.
            • February 28, 1975
            • 5138
            Yes, that looks like an oil line bracket (bent over). And yes, I would say that was mislocated because of the head swap left/right at some point in the car's past. The plastic oil line from the gauge enters the brass fitting with the compression fitting just above that, then there is a junction between that and the steel oil line and its fitting coming in from the block. The center of that junction slide into that notch in the bracket.
