70 Body Mount Hardware - NCRS Discussion Boards
  • Allen N.
    • January 1, 2003
    • 288
    The AIM indicates all 8 body mount bolts are GM # 3772263. My #1 mount bolts are worn and pitted. My #4 mount bolts has to be cut off. So these bolts are hard to determine the finish. My #2 and #3 mount bolts appear to have a zinc or cad finish. Is the zinc or cad finish correct for all 8 bolts?
    I have also not been able to determine the correct finish for the washers GM # 3830796 and the nuts GM # 3846854.
    Also, does anyone know of a parts suppliers who sells this hardware with the correct finishes? Most of the body mount kits look like everything is zinc plated except the aluminum spacers.
    Thanks for any help,
    Allen
    • 6950
    Re: 70 Body Mount Hardware
    Allen, I believe the repro blt kits are correct,even if the washers are plain from the factory, I do not believe there would be enough there for a deduct. get everything else correct such and the taped shims and frame marking and frame stencil.
    • Mike K.
      • February 25, 2010
      • 68
      Allen, I used the body mount kit from Paragon and did not receive any deduction when judged.
      • Allen N.
        • January 1, 2003
        • 288
        Thank you for the responses. I guess I'll order the kit from Paragon.
