65 steering shaft - NCRS Discussion Boards
65 steering shaft
  • Doug R.
    • November 2, 2009
    • 65
    65 steering shaft
    Just pulled my steering shaft to replace noisy lower bearing. I have two questions, 1 my steering shaft has grooves cut into from a bad bearing. From the info I have read from this forum I'm sure I need a new shaft,does anyone recommend one close to OE that I could buy. And 2 the lower bearing with the felt over the ballbearings,how and what do I lube them with? Thanks
  • Gene M.
    • April 1, 1985
    • 4232
    Re: 65 steering shaft
    Would you not just get a good used original from one of the many swap meets.
    • Doug R.
      • November 2, 2009
      • 65
      Thanks Gene for the reply,my car is down right now and looking for a solution in the next few days.
      • Harry S.
        • July 31, 2002
        • 5330
        Doug, I looked at this a few months back. Best I could tell there was one supplier to CC, CA, Paragon, LIC. Anyway the Corvette Central price is $84.95. Paragon is $85.00 but 10% off if you are an NCRS member. Good luck.
        On occasion NOS ones show up on eBay but I haven't seen one in awhile.
        • Doug R.
          • November 2, 2009
          • 65
          Thanks Harry
          • Leif A.
            • August 31, 1997
            • 3644
            Give David Sokolowski a call. He advertises in the Driveline.
            Leif
