First 100 miles on the 1963 Coupe - NCRS Discussion Boards
  • Richard G.
    • July 31, 1984
    • 1715
    I just passed 100 miles on the 63. ��
    The car is a blast to drive. A throw back to a bygone time…..
    No power steering with the 340-hp… Who would have thought and extra quart of oil is more important than p/s? ��
    It does add to the experience. In reality the car has a good road feel without the assist!
    Surprised how little one notices the lack of p/s until you have to park it!
    The Corvette rides like a truck without progressive wound springs. Corvettes got them in 64.
    So much sound is muted on the new cars. Don’t get me wrong on a long trip I prefer it.
    However, I wish side pipes were an option in 63, Id have them! The open air cleaner adds a lot of noise to the experience! Great fun sucking air.
    I am thrilled how nicely the stock shifter works. Smooth and reliable. A little stiff at first but I am confident that was the stiff shifter boot.
    Interesting choice by GM attaching the close ratio transmission to the 340 & 360HP motors. They lack low end torque to effectively launch the Corvette easly. With the 3:55 I notice getting the car moving requires some clutch slipping. With the standard ratio (3:70's) I likely would not be commenting on the transmission selection.
    I still haven’t driven the Corvette with the windows up.
    For some reason the air flow really isn’t annoying even at speed up to 60mph.
    I keep the vents open. Not sure why I don’t notice the wind so much. Because the car is so loud. Guess I don’t care! ��
    Its still warm on warm days, even with the extra Hushmat insulation. Sometimes I wonder if the heater is operating! Its not but you get the idea.
    More gear noise than I remember. Not sure why. It is noisy even in 4th so I believe its the rear differential. I notice the noise even in YouTube videos. Maybe its innate to the cars? Not annoying but its audible at times. Differential runs cool. After a 20 minute ride it will be 120 deg. Engine is 190. Transmission is 180. Transmission is running warmer than I would have suspected.
    The temp never go over 180 deg. even idling on hot days. GM did a good job of designing the cooling system. All new likely helps a bunch.
    Still running out of power for some reason above 4K. Will work on that but in general it still a blast and maybe it’s a signal to be nice to the old gal.
    Wish I would have replaced the rods for a little security…. Didn’t know what I know now when I rebuild the motor. Wish I would have had Duke's insights 30 years ago....
    RPM should be 2800 at 55 mph. I’m close even with the known incorrect speedometer gear. GM was only close as the speedometer was off by 3.5% when new. (I am confident GM picked the closest gear ratio that was slower than the actual speed) Didn’t want it to be over with the certain to come lawsuits if they did. I may be within 5mph. It was off 15% or double that. Possible a winter fix?
    The Corvette will spin the tires. The resulting noise (squealing) will wake up the dead or at least get the neighbors to look at the crazy man.
    Once started only a little gas keep the skinnyies going. I have only did this once. Forgot how much noise a radial can make. And ya it was fun.
    I realize I am likely to ding the paint sooner or later if I keep driving the car. Too much fun to quit. After owning the car for so long its just pure music.. Music I’m not likely to stop playing anytime soon.
    Rick
  • Gary R.
    • March 31, 1989
    • 1796
    Re: First 100 miles on the 1963 Coupe
    Forget about chips and drive the car, that's what it was made for- Enjoy, I would like to get another c2 to drive instead of working on them all the time.
    • Bob R.
      • June 30, 2002
      • 1595
      Rick,
      You noted that you were wondering if the heater is operating well there is no hot water shut off to the heating system and the heater box is always hot. If you did not take the box apart and replace the seals there is a good chance hot air is leaving the box and entering the passenger compartment.
      • Richard G.
        • July 31, 1984
        • 1715
        Bob;
        Thanks for the reminder. No, the box was not resealed. The 63 only heater is a long and expensive story I will save you the gory details and just give you the short story. The heater box will have to come out again as it has an incorrect box in it now. If anyone doesn't already know the radio side panels are also different in 63 and to install a later heater they have to be changed also. Its on my list to correct this. I currently have two 63 boxes and related hardware and a likely 64 or 65 box installed. Possibly I can tell the story at a later date.
        That said, I will reseal the 63 box before it is reinstalled. Appreciated the heads up.
        Rick
        • Bob R.
          • June 30, 2002
          • 1595
          The 63 heater box is the only one that has a snout to direct heat to the drivers foot and I think the control to actuate the heater door is also different on a 63 than the other mid years.
          • Joe R.
            • July 31, 1976
            • 4547
            Speaking of classic spins, back in 1976 my wife and I took a spin from Memphis to Orlando with the Vettemen Corvette Club of Memphis to the Court of Flags and the 1976 NCCC national meet at the Hyatt. I had side pipes on a 340hp 1963 Split Window Coupe. After I returned to Memphis and my hearing returned I threw the pipes and the covers in the trash! Yes, the trash!
            There were about 12 C-2's and a couple of C-3's. Wish I could do that again but not in July!
            JR
            • Ed H.
              • November 18, 2015
              • 192
              I just got mine back on the road in June after about 35 years. I concur with everything you said. Where ever I need to go, for most whatever reason, if the sun is shining (and yes have been rained on) it's my choice for transportation. And, even with PS, I avoid anything requiring parallel parking.
              • Richard G.
                • July 31, 1984
                • 1715
                Ed;
                How cool is that! Another Corvette on the road. Congratulations.
                BTW I have you beat by 2 years, down for 37. Interesting how many of these cars were purchased when we were in our 20's!
                Not exactly proud of the record but looking forward not back.
                I plan on having my car judged next year. Even if I don't change it out before then I understand the Heater is only worth a couple points.
                It's kind of weird to start the Corvette and find out it actually moves on its own! LOL.
                The solid lifter motor is a kick and sounds awesome.
                The kids all wonder what's wrong!
                Rick
                • Frank D.
                  • December 26, 2007
                  • 2703
                  Many, many cars are missing that snout and they are unobtanium....
                  I also thought the gear noise was excessive in my first few miles in the '63 - don't know if its because it is a coupe or my first midyear....I suspect a lot of sound is transmitted through the bare jack compartment.
                  If you keep the vents open then, yes, the air flow through the windows isn't annoying. You have to keep the wing windows cracked a bit in my experience or you start to get an annoying air "throb" pulsing through the car...
                  I don't know if your car is restored or you just got it but:
                  I don't agree on the ride; my springs in the front are the original ones though and I think they feel superb.
                  If you haven't already check out the rear suspension really well, trailing arm bushings, snubber bushing, half-shafts. Not just a ride quality issue but safety as well.
                  The all-drum brakes can be a little off-setting until you're used to them - more pedal travel than I'm used to; go over them as well if you haven't already.
                  As to dings - I got sick of touching up and wet-sanding the paint wondering when I will go thru to primer repairing road dings. I put Suntek, self-healing invisibe bra on the nose of the car and behind the rear wheels on the quarter panels (* GASP! *).... I don't notice it or even think about it anymore and driving is a lot less stressful..
                  Get real used to other drivers rolling up tight on your backside to snap a cell phone picture of the classic rear of the car.
                  It used to bug me but its so common now I just try to not worry about it much...
                  • Michael J.
                    • January 26, 2009
                    • 7072
                    You guys have many more years with yours than I do with mine. I got it just a couple months ago, but it has been sitting without being driven on the road, before and after restoration, for about 40 years. I drove it about 80 miles before the fuel pump went (it was put in new about 10 years ago when it was restored), and then the fuel unit needed to be refurbished after sitting so long after restoration, and it needed tuning and a new VAC, etc., but now it is back on the road and I hope to hit 100 miles very soon. The car looks perfect, but as we all know, if you don't drive them as they were intended to be driven, they will be trouble. Drive 'em and enjoy 'em!
                    • Ed H.
                      • November 18, 2015
                      • 192
                      Originally posted by Richard Geier (7745)
                      Ed;
                      Rick
                      Indeed. A mechanical symphony ;-)
