1966 gauge cluster label LD - NCRS Discussion Boards
  • Tony S.
    NCRS Vice President, Director Region VII & 10
    • April 30, 1981
    • 991
    I just removed the gauge cluster from my barn find 1966 convertible and found a red and white LD label on the back. I've seen LA, LB and even LC. I've never seen an LD. Can someone tell me what the LD signifies? Thanks, Tony
    Region VII Director (serving members in Arkansas, Kansas, Louisiana, Missouri, Oklahoma and Texas).
    Original member of the Kansas City Chapter, est'd 07/11/1982.
    Member: 1965 and 1966 National Judging Teams
    Judging Chairman--Kansas City Chapter.
    Co-Editor of the 1965 TIM and JG, 6th and 7th editions.
  • Robert G.
    • May 31, 1990
    • 429
    Re: 1966 gauge cluster label LD
    Here are a couple of threads, I may have the LD info somewhere but I'll have to do some searching.
    https://www.forums.ncrs.org/showthre...hlight=6457982
    https://www.forums.ncrs.org/showthread.php?109876-Instrument-cluster-Date-stamp&highlight=6457982
    https://www.forums.ncrs.org/showthre...hlight=6455367
    • Tony S.
      • April 30, 1981
      • 991
      Here are a couple of photos of the gauge cluster and label. It is from my April, 1966 L36 car.
      • Frank E.
        • May 31, 1986
        • 189
        Tony...
        I did my cluster last fall and found the same LD label as you have. I have a base '66 300HP 4 spd. Here's the photo of the label that I"m sure matches yours.... I had my speedo/odo repaired by Joe Ray and he said that someone had been in the speedometer before. I've owned the car for 32 years and this is the first time I've had the cluster out. So the repair was made previously and I can't verify that it's an original cluster backplate. However, the stamped date code was so faint and the patina of the backplate was really aged before I cleaned it. that I'm pretty sure it wasn't changed out. I've included a front view of the finished cluster so you can see the configurations.
        Frank
        1966 Milano Maroon Roadster
        2004 CE Z06
