1966 corvette, no headlights, no dash lights or brake lights. - NCRS Discussion Boards
  • Joe T.
    • February 25, 2018
    • 153
    Went to raise headlights and car stalled and then had nothing when turning the key to start. Moved wires around on headlight door open close switch and got sparks. Spread wires apart and got car started. Now I have parking lights front and back. I can turn interior lights off and on by turning headlight/parking light switch. I now have no headlights, dash lights or brake lights. Nothing happens when pressing high and low beam switch. Fuses look good but I haven't pulled or test them. Need help.... I have a 1966 assembly manual.
  • Kenneth T.
    • April 27, 2009
    • 85
    Re: 1966 corvette, no headlights, no dash lights or brake lights.
    Check the connection of the wiring harness in the back of the fuse block firewall side
    • Joe T.
      • February 25, 2018
      • 153
      I found the problems.. Bad Hi/Lo beam switch connector, headlight door open/close switch and headlight switch not send power to fuse (3rd one up from bottom).
