Tachometer Drive Unit - NCRS Discussion Boards
+ More Options
Posts
  • Patrick S.
    • January 1, 1988
    • 209
    My rebuilt tachometer indicates about 25% over the engine speed. I checked the pullies on the crank, w/p and generator and they are all the right size. Put on a known good tach and it reads the same, put on a reduction unit (25%) on the back of the drive unit and the reading appears right. Are there more than one size gears in the drive unit?
  • Troy P.
    • February 1, 1989
    • 1284
    Re: Tachometer Drive Unit
    Interesting issue. I also wonder if you have the wrong drive unit in your tach.
    • Patrick S.
      • January 1, 1988
      • 209
      I've tried 3 different tachs and they all read the same 25% high.
      • Ken A.
        • July 31, 1986
        • 929
        There is no such as a drive unit in the tach.
        • Richard P.
          • July 31, 1995
          • 57
          I wonder if the issue is the generator pulley? If it is undersized it would give a higher reading at the tach.
          • Patrick S.
            • January 1, 1988
            • 209
            The pulley on the crank and generator are the right diameter and width (groove). Still baffled
            • Rod K.
              • 443
              Believe there were two different pulleys used, one 3-5/8 dia for Corvette and one 3-3/8 dia for low HP and pass applications. Larger dia took a 1/2" wide belt vs 3/8" for low HP. The smaller one wouldn't account for 25% error but would be over by about 7%. Narrow belt in a wide groove would run faster as well.
