1959 Blower Motor - NCRS Discussion Boards
1959 Blower Motor
  • Jeff S.
    • February 1, 2005
    • 73
    1959 Blower Motor
    My 1959 blower motor does not spin. Can this part be taken off and rebuilt? Thank you for any help.
    • 6960
    Re: 1959 Blower Motor
    Jeff, try using some 3n1 oil, remove the blower cage, and the other end is sealed but if you drill a small 1/16 hole on the tip of motor the will let you get some oil on the end of motor- this end I has a bronze bushing the other end is a bearing(cage end). if all works seal the end with JB weld.
    • Terry D.
      • May 31, 1987
      • 2698
      Jeff
      Yes these can be rebuilt, take it apart and clean and lightly sand parts and see if this helps.
      • Jeff S.
        • February 1, 2005
        • 73
        I will take the cage off today and let you know what I have found. thanks for the input!
        • Jeff S.
          • February 1, 2005
          • 73
          Terry, I was able to take the motor apart and clean and lube it. the motor works fine. thank you for your help
