L78 HT cable from distributor cap to coil. Which way round. - NCRS Discussion Boards
  • Gary C.
    • April 1, 1998
    • 380
    My L78 high tension cable from the coil to the distributor has a right angle plug at one end and a straight at the other.
    If I connect it so the right angle is at the distributor and the straight at the coil the top the shield seems to squash the cable.
    The AIM shows a straight plug at each end. The JG does not mention it.
    Perhaps the Electric Ltd set is not like the original. Whats the go?
    Gary
    • 6955
    Re: L78 HT cable from distributor cap to coil. Which way round.
    Gary, I believe the wire can only go one way, tower on the coil is slightly larger?? is one of the boots larger??
    • Gary C.
      • April 1, 1998
      • 380
      It looks like the right angle plug fits on the distributor but it will go either way.
        • 6955
        Gary, that's my bet how it goes.
        • Ray K.
          • July 31, 1985
          • 375
          Gary,
          From my original L78 - the right angle boot goes on the coil and the straight boot into the distributor cap.
          Ray
          • Gary C.
            • April 1, 1998
            • 380
            There is less compression on the cable from the lid when the right angle plug is on the coil. I have tried to shoe it here;
              • 6955
              Gary just a thought is the coil in its lowest point on the mounting bracket?
              • Carl N.
                • April 30, 1984
                • 592
                Ray & Ed are correct. Make sure coil is almost touching intake. Should have plastic sheild inside lid which will compress wires
                • Gary C.
                  • April 1, 1998
                  • 380
                  Yes coil is almost touching the intake.
