What happened to Quanta??? - NCRS Discussion Boards
  • Michael L.
    • December 15, 2006
    • 1413
    guys I'm trying to get some frame resto products and have ordered many times from the folks at Quanta but I can't find them on the internet anymore. I mainly just need a green lumbar crayon. I ordered my chassis detailing kit so long ago that the crayon has dried out and I need a new one. anyone know where they went???
    Mike
  • Joseph S.
    National Judging Chairman
    • March 1, 1985
    • 927
    Re: What happened to Quanta???
    Mike, The crayons don't dry all the way out. Get a razor blade and shave the first 1/4" off the crayon. What is under should work great after that.
    • Dick W.
      • 10483
      Dick Whittington
      • Mike B.
        • July 31, 1994
        • 843
        Scared me!
        Quanta is still in operation. Was just on their site on-line. Gastanks.com. Saw a notice they'll be in Carlisle. Had to call. Spoke to a nice lady. All is well as far as my future '66 gas tank goes!
        Mike
        • Justin S.
          • July 3, 2013
          • 305
          They're missing a couple words from their site. It should be horriblyfittinggastanks.com
          • Mike B.
            • July 31, 1994
            • 843
            Justin,
            Uh oh. What year application?
            Mike
            • Justin S.
              • July 3, 2013
              • 305
              70 and despite complaints here and I'm assuming with their technical support staff, they are oblivious to the defect.
              • Michael L.
                • December 15, 2006
                • 1413
                What was wrong with the fit? I have their tank for my 69 and just about ready to lower the body. Is there anything I can do to help avoid problems?
                Mike
                • Justin S.
                  • July 3, 2013
                  • 305
                  Mike,
                  You're way ahead of me because the original straps are too short to make it around the tank. All of this even after adjustments to the seam with duckbill pliers and a ball peen hammer which leads me to believe the physical dimensions are not of OE spec.
                  Justin
                  • Brian M.
                    • February 1, 1997
                    • 1840
                    My 67 tank fit with NO issues.
                    • Jeffrey S.
                      • May 31, 1988
                      • 1898
                      Mike
                      Unless something has changed, your '69 tank should fit perfect as mine did. I put a new Quanta tank in my '69 several years ago (body on) and it went in perfectly. Before the install I compared my original tank with the new one and could not find a single difference. I was very happy with the product.
                      Jeff
                      • Michael L.
                        • December 15, 2006
                        • 1413
                        Ahhh yes I had a VERY tough time getting my straps around the tank also but eventually I managed to get it. It took the better part of a full day. This was probably the toughest part of the resto, believe it or not. Not sure if this is a factory thing or from the repro tank.
                        Mike
                        • Mike B.
                          • July 31, 1994
                          • 843
                          Brian,
                          Glad to hear your '67 tank went well. Did you use your original straps?
                          Mike
                          • Mike M.
                            • May 31, 1974
                            • 8405
                            i've used quanta tanks for years in c-1, c-2 and c-3's. never had a problem with the tank fitting up in its "home". i usually re-use the original straps. mike
                            • Brian M.
                              • February 1, 1997
                              • 1840
                              Yes I Did.
