Light switch removal trouble - NCRS Discussion Boards
  • John F.
    • March 23, 2008
    • 2413
    You can't feel any detent when pulling out the light switch to "park", or to headlights "on". I held the button "in" and tried to pull the knob out. The knob will not come out. I purchased a new switch, but need to get the old one out first. If the the old one is original, maybe I can salvage it. Any pointers on getting the button to release the knob?
    • 6948
    Re: Light switch removal trouble
    John, its been a while, But I believe you pull to the park light position first then then push the button in, then slightly in just a bit then pull it out.
    • John F.
      • March 23, 2008
      • 2413
      Okay. I got it out. A little corrosion on all contacts. So, I took it apart w/o loosing any springs. Put it back together, and now the pull lever will not catch inside. I tried the new one right out of the package and the same thing. I don't want to take the new one apart. What did I do wrong?
      • John F.
        • March 23, 2008
        • 2413
        Played and played with the button, and now it works. All done!
