diy conversion of voltage regulator for 65 - NCRS Discussion Boards
  • Stephen B.
    • April 1, 1988
    • 879
    Has anyone done this themselves?
    The hooked an A/C source (vintage American Flyer train transformer) to the connections on the left (F and 2) and measured the DC from the right terminals (3 & 4). The A/C voltage was varied between 7 and 16 volts. All I got was .15 volts on the DC side, which was the same DC voltage produced by the A/C transformer. I noticed that the farthest left connection (F) is the grounded to the case and the heat sink for the power transistor.
    I purchased a new, generic electronic regulator for the donor components.
    Any ideas as to why I don't have proper level DC voltage? What is the A/C voltage supposed to be from the alternator that's fed into the regulator.
    Thanks in advance...
  • Dan D.
    • November 5, 2008
    • 1323
    Re: diy conversion of voltage regulator for 65
    Steve, the alternator supplies DC to the regulator. That's what the six diodes in the alternator do. You need to use a DC power supply in order to test your regulator.
    -Dan-
    • Stephen B.
      • April 1, 1988
      • 879
      aha! I knew I'd had forgotten a critical fact. I'll try it tonight.
