I am perplexed. In checking all the electric functions after hooking up the battery for the first time, I found that the windshield wiper motor would not turn on. It draws power from the inboard ballast resistor terminal which in turn is powered by a brown wire running directly from the ignition switch. I tried jumping the ignition switch terminals and the motor engaged for a split second then stopped. I inserted two mini screwdrivers in the brown wire and red wire connection terminals and verified power across this connection. Still no power at the ballast resistor. I managed to stretch an ohm meter wire from the terminal of the brown wire at the resistor to where it terminates in the connection at the rear of the ignition switch. It was quite a stretch but presuming that the meter terminals were making good contact then I must have an open circuit in this brand new harness which seems far fetched. Does anyone have any idea of what is causing this and what the fix might be? I'm thinking that I am going to have to abandon the brown wire, open up the harness tape and run a new dedicated wire to the resistor from the ignition switch.
