C2 Rear Spring plate mounting Bolt finish - NCRS Discussion Boards
  • Tim S.
    • March 1, 1989
    • 124
    Are the four bolts for the C2 mounting plate to the differential zinc (cad) plated or natural phosphate in color.
    Thank you
  • Ed S.
    • August 6, 2014
    • 1377
    Re: C2 Rear Spring plate mounting Bolt finish
    Tim,
    First, when you say "mounting plate" I assume you are talking about the rectangular plate that goes under the spring, the one that holds the spring up against the bottom of the differential. If you are referring to those bolts I am quite sure they are black phosphorous,they are not zinc. That is true for a '64. Don't know if the finish is different for other mid years.
    Ed
    • Richard G.
      • July 31, 1984
      • 1718
      The 63 bolts are also
      black phosphorous.
      Be sure to complete the final bolt torqueing sequence after the car weight is on the spring.
      • Russ S.
        • April 30, 1982
        • 2163
        Richard, I wouldn't call it the final bolt torquing sequence as that would tend to indicate that the bolts can be tightened down to nearly tight before setting the car weight on the spring when in reality the weight needs to be on the spring before the bolts are tightened to the point of final torquing. The weight should be set on the spring soon after the bolts start straightening the spring arc out.
        black phosphorous.
          • 43247
          Thank you
          Tim------
          The 63 to at least 1974 bolts were black phosphate.
          Sometime after 1974 (1977 as I recall) the bolts changed to 7/16" from the 63-74 9/16". As I vaguely recall, the later 7/16" bolts might have been zinc plated. I can't check this at the moment as I'm in Italy.
            • 6950
            Tim,
            one other important part of the rear spring plate bolts are there length , There have been many rear housings plates cracked over the years, the after market or repro bolts are all to long, be sure to re-use your original bolts. (4 1/4" long).
            • Ed S.
              • August 6, 2014
              • 1377
              So, my question is, when the bolts are initially run in with out the weight of the car on the spring - how tight should they be? I am in this situation right now. Car is up on stands, I have reinstalled the diff and complete rear suspension. Being aware of the DO NOT TIGHTEN issue (from this thread) I ran the bolts for the spring plate in by hand and then tightened them with a socket wrench up to the point where the lock washers were just about to begin closing - they were still "open" or in their natural non compressed state. At that point everything is snug and not able to move around. Plan is to tighten to specified torque values when the car is sitting on the ground. Is what I just described satisfactory?
              Ed
              • Stephen L.
                • May 31, 1984
                • 3161
                Ed, Your procedure to tighten after the weight is on the suspension is correct.... Just enough torque to keep things in place. Hang a note on the suspension to tighten later so you don't forget and drive the car....
                The same procedure is applicable to all suspension pieces, bushings etc. Don't tighten until the car is on the ground......
                • Russ S.
                  • April 30, 1982
                  • 2163
                  Ed. Yes that would be good.
