1967 Headlight Motor Finishes - NCRS Discussion Boards
  • Tim S.
    • March 1, 1989
    • 124
    What is the correct finish for the 1967 headlight motor assembly.
    I think the cast gear housing is pot metal in a natural finish. I am not sure of the finish on the motor winding cases. I see some black, some that are the same color as the gear housing.
    I did not see a reference in the new Judging manual for this item. Many of them have been rebuilt and
    the builder may have spray them. Pictures would be helpful.
    Thank You.
  • Joe R.
    • July 31, 1976
    • 4550
    Re: 1967 Headlight Motor Finishes
    The gear housing is natural with the motor housing being natural stamped steel.
    Most 63's have a black connector and later 64 and up have a white connector.
    The bearing for the shaft to the bucket is white.
    The screw and star washer for the ground wire is cad plated or zinc.
    JR
