Starting a 340 hp after 37 years! - NCRS Discussion Boards
  • Richard G.
    • July 31, 1984
    • 1715
    Well it happened this week the motor in my 1963 is running again after may years. (Or decades but who is counting).
    It was in stages;
    • Solve the fuel line leaks.
    • Determine the distributor is on compression stroke as the timing mark had moved, from zero.
    Likely the car was bumped/moved with the transmission in gear. This wasn't planed as it was on tdc #6 when I matched the timing marks to install the timing chain. Then rolled one turn for TDC #1 compression stroke.
    Pulled the valve cover and confirm #1 compression by watching the valve sequence.
    • Motor attempts to start. Coughs and sputters
    • Determine the distributor is off by one tooth.
    • Fix leaking radiator hose at the tower clamp.
    • Wait a full day for help. Pull the distributor rotate one tooth on the cam and have buddy/friend/wife hit the starter while pushing down on the distributor till it falls into the oil pump notch. Confirm by bumping the engine over till timing marks and #1 line up.
    • Motor starts and runs but could be better. High 5's all around in the noise. Rotate distributor enough to get the motor to run acceptable. Attempted to run the motor for 20 min at 2000 rpm for cam break-in. Starts to dump water after about 15 min. Motor shut down for the day. Lots of other things, not motor related, can use attention.
    • Next day determine the 55 year old radiator cap is identified as the cause of the leak. Purchase replacement cap. Attempt to start the motor again. This time I determine timing is still off by one tooth. (Or and additional tooth if you count the first distributor move)
    • Wait a full day for help. Move distributor another tooth. (There is very little room to time the distributor as the vacuum canister hits the intake manifold on one side and the coil bracket on the other. Starts and runs at an idle this time. Set the timing by ear. Celebrate with a beer and my friend Bill that helps me all the time. Bitter sweet moment. Bitter it took so long, sweet its running again.
    • Next day set the timing with a light and the idle speed. Idles nicely at 850 rpm. (Used the 2" rule and replaced the stock vacuum canister and the advance springs). Thanks Duke! Motor idles amazingly well.
    • Choke isn't working but it starts right up on a warm summer day. I believe it only requires adjustment?
    • Take a video of the motor running and send to anyone who cares and some that don't!
    • Start and run the car often just to be sure its real and nothing has failed.
    • Starts right up after shutting it off. Flick of the key and it going. Very satiating. Love the sound of the solid lifters!
    This project lasted through a divorce, two children and a second marriage. My children are in their 30's and have never seen this car run before. In the past I didn't have the time or the money. Now, I have both. Many thanks to my wife, Margaret. As she only complains about my shop time occasionally. (:
    Thanks to everyone for all the encouragement and knowledge sharing. Their is simply no way this Corvette would be as nice as it is without your advice. I am constantly at awe at the collective knowledge that is shared on this forum.
    Nite.
    Rick
  • Joe R.
    • May 31, 2006
    • 1822
    Re: Starting a 340 hp after 37 years!
    Congratulations! I can tell you are pumped!
    Joe
      • 6940
      Rich, its nice to be able to bring the car out of hiding after so many years. Its another corvette brought back to life, and a split window so many people young and old know its heritage. enjoy it.
      • Peter M.
        • May 30, 2013
        • 358
        Rich,
        Congratulations! I bet even at that time of night you still couldn't get to sleep.
        Kind Regards
        • Leif A.
          • August 31, 1997
          • 3619
          Rich,
          You have earned the right to be giddy. Anticipation is quite the elixir. Can't wait to see some pictures and hear some videos. I just know you're going to enjoy putting the miles on her. Congratulations!!
          Leif
          • Stewart L.
            • March 1, 1980
            • 353
            Rich,
            Im glad you have it running. I guess we should have had our chapter meet in August instead of June. I'm looking forward to seeing your car.
            Stewart
            • Thomas S.
              • February 7, 2016
              • 612
              Now that was a great story with a happy ending.
              67 427/400 Lynndale Blue Corvette https://online.flippingbook.com/view/750924569
              • Ed H.
                • November 1, 1999
                • 626
                Rich,
                There is no sound better than a solid lifter, 30/30 Duntov designed cam, in a 327 11:1 motor, other than screaming up the Pacific Coast Hiway
                early on a Sunday morning listing to the exhaust at 6,000 RPM. Oh for the old days!
                • Richard G.
                  • July 31, 1984
                  • 1715
                  What the other drivers get to see.
                  • Thomas S.
                    • February 7, 2016
                    • 612
                    That would be very fast - What axle ratio do you have?
                    • Richard G.
                      • July 31, 1984
                      • 1715
                      3:55.
                      Born with 4:11.
                      The 3:55 gears have a 1965 date on them. (GM gears)
                      Easy enough to figure out how the 4:11 might have gotten old quick. Even at $.25 cents a gallon.
                      Back (well way back) I took a 400 mile road trip and averaged 18mpg.
                      The fast comment was of course tongue and cheek.
                      Nothing that was state of the art in 1963 will compare to a new Corvette.
                      I read where a Dodge Mini-van does the slalom in the same time a 67 Corvette can do it.
                      It does compare in Looks.
                      Rick
                      • James G.
                        • May 31, 1976
                        • 1556
                        GREAT STORY Rick. So much fun to see a great old 63 SWC back driving those beautiful Washington Highways. Will you be at the NATIONAL in Vegas in two weeks? Love to see you. I will be there Tuesday and Wednesday July 17 and 18.
                        • Richard G.
                          • July 31, 1984
                          • 1715
                          I have been to four of the NCRS Nationals but never with a car of course.
                          I can't make it to Vegas this year.
                          Rick
