Water pump casting number help please - NCRS Discussion Boards
  • Donald H.
    • November 2, 2009
    • 2580
    My 67 had a casting number 3839175 pump on it when I got it. I put a rebuilt 3859326 on it.
    What was the 3839175 used on? I’m seen some reference to it being used on 64 SHP engines and also a reference that it was used on small block marine engines.
    i need a bypass pump for my 65 El Camino that is dressed as an L79, would the 3839175 be OK?
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
  • Greg W.
    • February 26, 2015
    • 141
      • 43218
      Re: Water pump casting number help please
      Don------
      I believe the 3839175 was used after the 1965 period. If yours has a date on it that works for the car, I'd say it's probably original to the car. Of course, if it has no date or it has a date that doesn't fit, then it's not original to the car.
      The 3839175 was used during the 63-65 period for applications requiring external bypass. It was also produced into the early 70's and possibly later for SERVICE for all 1955-1970 Corvettes and 1955-68 Chevrolets. It will work just fine for your Chevelle application.
      • Donald H.
        • November 2, 2009
        • 2580
        Thanks Joe
        Don Harris
