Chassis numbers - NCRS Discussion Boards
Chassis numbers
  • Dale S.
    Infrequent User
    • December 7, 2011
    • 10
    Chassis numbers
    Should I leave the original stenciled numbers or repaint, also is there a process to document other than pictures. Thanks for your help. I am doing a full frame off restoration. I have had this car since 65 all matching numbers and has been in my garage, thanks again.
  • Gary C.
    Administrator
    • October 1, 1982
    • 17940
    Re: Chassis numbers
    Dale,
    Depends on how bad the stencil is.
    Options that you should do are:
    1) trace stencil onto tracing paper - good enough to make a stencil from if need be
    2) take detail measurements of stencil; a) length and height of each number/letter, b) dimension (space) between each letter, c) dimension (space) from all frame holes, d) dimension (space) from the top and bottom rails, e) determine if number/letters justificationl, left, center or right
    Good luck,
    Gary
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • John F.
      • March 23, 2008
      • 2420
      Re: Chassis numbers
      And take photos of the frame sitting there with the clear shot of the stencil.
      • Jim D.
        • 2885
        Re: Chassis numbers
        You may also want to use a mild cleaner, like Simple Green, and clean the areas where the pull date and shim markings would be and document them as well.
        • Edward B.
          • January 1, 1988
          • 537
          Re: Chassis numbers
          Take your lead from Forensic Photography 101 and include a ruler in the picture to allow accurate scaling of the characters and their placement. Including a date stamp on the image is also highly suggested. Take more pictures from various angles than you think you will ever need.
