Picture of the capacitor behind the amp gauge on a 1963? - NCRS Discussion Boards
  • Richard G.
    • July 31, 1984
    • 1715
    Does anyone have a picture of the capacitor behind the amp gauge on a 1963?
    This is a very busy area of the dash with the headlight switch and capacitor almost on top of each other.
    It connects to the small screw that retains the gauge pod and the wire connects to one leg of the amp gauge.
    The assemble manual shows it but I havn't been able to get it installed in any manner that looks like something GM would do.
    Rick
  • Stephen L.
    • May 31, 1984
    • 3159
    • Richard G.
      • July 31, 1984
      • 1715
      Re: Picture of the capacitor behind the amp gauge on a 1963?
      Sure looks like it might be the same. Makes sense it would lay as shown.
      I now suspect the clamp on the capacitor may not be the correct one as makes the cap stick out so far enough as to make mounting the cap in this position is impossible. It is an original cap and bracket. However, the center of the clamp to the hole center may be too great a distance to mount it in the manner shown.
      Thanks for the picture and response. I now have some direction.
      Rick
      • Joe R.
        • July 31, 1976
        • 4551
        Richard,
        Here's a pic of the capacitors on the back of all 1963-1967 C-2 Corvettes. They were the same on all C-2 Corvettes. Note the clamps have an extreme bend so as to keep the capacitor from showing below the instrument bezel.
        The clamps in the center that have been plated are only on NCRS Duntov Award Winners. Yeah, Right!
        JR
        • Frank D.
          • December 27, 2007
          • 2703
          Ny 63s capacitor is mounted identically to those shown above......makes doing certain things in that area a pain in the rear....
          • Michael J.
            • January 27, 2009
            • 7145
            Here's a picture of my '63:
            • Richard G.
              • July 31, 1984
              • 1715
              Michael;
              Thanks for taking the time to get and post a picture. Makes it difficult to get the cap installed correctly, with the dash installed, as one cant get to the screw with the bend in the bracket. Also makes it impossible to install and then bend as the support is in the way. Makes it obvious, when the cars were built, the caps were installed and then bent over before the dash installation.
              I also noticed "J" nuts on the headlight rotation switch. All the vendors sell a clip that isn't a "J" clip but like the back halve only (i.e. not bend in the clip it's just flat with a screw hole in it. Certainly would be an easier install with "J" clips. Don't ask how I know!
              Rick
              • Joe R.
                • July 31, 1976
                • 4551
                Richard,
                The J nuts work a lot easier BUT are not original. The flat nut plates is what was used by GM or Delco.
                JR
                • Michael J.
                  • January 27, 2009
                  • 7145
                  I really had not looked closely in this area before I took this picture. It is a tight mess, but since my '63 did not come equipped with a radio, now I am wondering if that capacitor should be there in the first place.........
                  • Richard G.
                    • July 31, 1984
                    • 1715
                    no radio = no caps.
                    • Michael J.
                      • January 27, 2009
                      • 7145
                      OK, I knew it, back to the garage..........
