Tire Question - NCRS Discussion Boards
Tire Question
  • Sven C.
    • July 18, 2015
    • 189
    Tire Question
    This came out of a 1963 as a spare and having some confusion trying to date code it. First pic shows a code JP0535B on the inboard side of the tire and it appears to be the only code that resembles a date code on the tire, but DOT does not precede the code nor is DOT anywhere near it. It is a Goodyear Power Cushion Polyglas F78-15 and the rubber is as hard as a rock. Not suggesting that it is an original spare, but the information that I have found to decode the date so far doesn't seem to make any sense. Any help would be greatly appreciated.
    1963 Corvette: Flight Judging Award (Top Flight) at 2023 Ontario NCRS Regional Meet (Regional) at 09-14-2023
    1963 Corvette: Flight Judging Award (Top Flight) at 2023 National Convention-French Lick (National) at 07-27-2023
    1963 Corvette: Flight Judging Award (Top Flight) at NCRS Indiana Regional (Regional) at 04-28-2022
    1963 Corvette: Flight Judging Award (Top Flight) at Ontario Chapter judging Meet 2021 (Chapter) at 09-18-2021
  • Gary C.
    Administrator
    • October 1, 1982
    • 17916
    Re: Tire Question
    Sven,
    1968/1969 time frame the tire companies started using a DOT standard tire code format.
    Before DOT, somewhere in mid 1960's some of the tire companies started using a type of standardized format. Previously, all the tire codes were proprietary. Which requires a lot of Internet searching to find tire codes.
    Attached is a Goodyear document which might provide some insight for you.
    Gary
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Sven C.
      • July 18, 2015
      • 189
      Re: Tire Question
      Gary,
      Thanks for the info. Will have a read and see if I can figure it out.
