68 Caliper machining - NCRS Discussion Boards
  • Jeff P.
    • 799
    Can I have some opinions on what we use. Sandpaper,Drexel,scotchbrite. Thanks in advance. Jeff
    68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
    2014 Arctic White Z51 Vert. (Wifes)
  • Gene M.
    • April 1, 1985
    • 4232
    Re: 68 Caliper machining
    Looks good to me, there are other areas spotfaced machined at holes too. Yes wiz wheel, scotch brite and sand disc all work well.
    • Jeff P.
      • 799
      thanks,Gene. Anyone have a better photo of a complete unit ?
        • 11678
        You're welcome for the photo.
        I just tape them off when I paint, then use acetone to remove any paint still on the machined areas. It works much better than trying to sand them or whatever. Q-tips work great.
        I've even removed paint in these areas from fully-painted calipers.
        You're making it much tougher than it needs to be by sanding them or whatever.
