Hello all.
Although my engine idles and revs up fine in the garage (nice and smooth, no hiccups or sounds) I thought I'd check my ignition timing (Note: It's running very poorly once on the road, even at very little load/gas it is very rough/missing (hence my check on the timing), but that's another story...). The timing is way up there around 12 degrees BTDC. It's off the marking tab, so I'm estimating (BTW: why does the marking tab max out at 8 degrees when the spec timing is (I believe) 8 degrees BTDC @ 700 rpm?). Dwell is fine/steady at 30 degrees. [I'm surprised it runs fine (in the garage with no load) with such a large advance.... Could my poor-running when-loaded motor, as mentioned above, be due to such a high advance? Never noticed any detonation.]
Here's the problem: when I try to reduce the timing by rotating the distributor clockwise (when looking down on the distributor) the vacuum advance hits my coil (coil is mounted right and has not shifted/moved). The lowest I can get the advance is ~12 degrees BTDC. Almost seems as if the distributor is off a tooth (on cam), but this "can't" be since the car was running fine for years after my rebuild. (I recently rebuilt the carb because the car was running poorly at higher rpm. I did this to address the "another story" I mentioned earlier).
Any thoughts are much appreciated !
-Mark
-Mark
