63-64 Front Valence removal and replacement - NCRS Discussion Boards
  • Dan B.
    • July 13, 2011
    • 545
    Re: 63-64 Front Valence removal and replacement
    Originally posted by Douglas Lee (40617)
    Dan,
    Can you post a few pictures taken from the front of the car showing the approximate bonding point of the valence panel to the left and right turn signal panels and one of the valence panel and the turn signal panels all included?
    The approximate bonding point if you want to eyeball it on your car is where the lower screw hole is for each of the grill corner moldings.
      • 6950
      Don't forget to add the position off the support rods to valance ( Philips screws) this should help place the valance to its correct position. there maybe some forgiveness.
      • Brian K.
        • May 31, 2004
        • 358
        #18
        Hold the valance to the parking light panels and bonding strips with vise grips. Then test fit your grille to the mounting tabs, making sure you have equal distance between the grille and parking light panels on both sides and along the bottom of grille and valance. Move valance to center grille as needed.
