Correct vacuum canister on a 300/327? - NCRS Discussion Boards
  • John F.
    • March 23, 2008
    • 2417
    What is the correct vacuum canister for a 300hp/327?
  • Harry S.
    • July 31, 2002
    • 5333
    Re: Correct vacuum canister on a 300/327?
    John,
    Depending on your year, this may be it. https://www.ebay.com/itm/1959-1963-C...4AAOSw4vJavMKK
    Look elsewhere as this price is over the top.
    • John F.
      • March 23, 2008
      • 2417
      It is for my 64 corvette. The judging sheet said "236 can- hhp engine". 2 point deduct.
        • 43259
        John------
        The original was the GM #1116201. This vacuum control was discontinued by GM in January, 1965 and replaced by GM #1116163. However, the 1116201 may have been available through Delco after it was discontinued by the GM parts system.
          • 15706
          It will be extremely difficult to find a 201 15 since they have not been available from GMPD for over 50 years and the 163 if you can find one requires too much vacuum to pull to the limit. The 236 was only used on the 365/375 HP engines.
          A functionally correct replacement is the 15" B22, NAPA VC1802 or equivalent in another brand. ALL are the same part made by Standard Motor Products and stamped B22 regardless of the name on the box.
          Often the stamped data is not visible with the cap fully seated, but there may be some slight difference in the configuration, like the crimp.
          Since the VAC is only worth 3 points - two for originality and one for condition, what was the reason for the 2-point deduction, and what is the number on the currently installed VAC.
          • John F.
            • March 23, 2008
            • 2417
            Duke, here is a picture of what is on the car now. It looks like 236. I guess I should just leave it over 2 points.
              • 15706
              I can't see the numbers in your photos. Unlatch the cap and raise it slightly and read what is stamped on the VAC mount bracket. No photo necessary - just report the stamped data.
              • John F.
                • March 23, 2008
                • 2417
                Duke, you can see the 2 & 3 & top of the 6 in the second photo if you zoom in.
                • Harry S.
                  • July 31, 2002
                  • 5333
                  Duke, I agree that a two point deduction is incorrect. Looks like it should have been 4/10 of a point or .4. Should have been slashed with a comment.
                  • John F.
                    • March 23, 2008
                    • 2417
                    Are you saying that even though this is the incorrect part for a 300hp, it is still okay rather than buy an aftermarket?
                    • Donald H.
                      • November 2, 2009
                      • 2586
                      Paragon sells a reproduction (other vendors may also) stamped 201. I have not used one so I can say if it test correct or not.
                      Don Harris
                      Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
                        • 15706
                        I would be very careful of "reproductions". At least in the past some have been discovered with the "correct" stamped data, but were not even remotely close in start and stop points.
                        I consider the SMP manufactured VACs to be OE replacement, so in chapter judging if the book specifies the stamped data and I can see it and it's not correct, I'll take off one originality point. If I can't see the stamped data and the surface plating is near new, no deduction.
                        The trouble with a 236 16 is that it is way more aggressive (start @ 4", 16 @ 8") than necessary for a 300 HP engine, and in some cases may cause detonation, especially transient when the throttle is opened partially to accelerate. The 15" B22, which has nearly identical specs to the 201 15 is the least aggressive VAC that meets the Two-Inch Rule because typical idle vacuum for a 300 HP engine is 18-19" @ 500 in neutral and about 17" at the same speed in Drive with an automatic.
                        These replacement VACs cost about ten bucks, and if your 236 16 still meets spec and doesn't have any visible rust, it's probably worth more. It was OE on 30-30 cam engines and L-79s, but is too aggressive for the latter which typically idles at 750 @ 14-15", so the 12" B26 is a better functional fit.
                        • Harry S.
                          • July 31, 2002
                          • 5333
                          Duke, how do you take a 50% deduction? If the stamped data is incorrect then it's a confiruration hit of 20%. 20% of 2 points is .4. Essentilly there is no deduction unless you start counting dots.
                          I'm assuming you assigned 2 points out of the 15 to the vacuum advance.
                            • 15706
                            Perhaps I was being too harsh. The VAC is only worth 3 points - 2 for originality and 1 for condition. I do make "half point" notes and take a point on the next half point observation.
                            In a previous discussion of this subject a few years ago someone claimed that if the VAC number didn't match, he took the full three points. You should talk to him.
                            • Gene M.
                              • April 1, 1985
                              • 4232
                              You do realize 2 points, that is .04% ................... next to nothing, not even a consideration in the great over all picture of things.
