Engine Wiring Harness Recommendation for 1963 - NCRS Discussion Boards
  • Dave S.
    • August 31, 1992
    • 2926
    Im replacing the engine harness and I'm looking for a Vendor recommendation. It seems like many vendors sell them and Lectric Limited is the best known brand. Any guidance from those who have done them is appreciated.
  • Leif A.
    • August 31, 1997
    • 3645
    Re: Engine Wiring Harness Recommendation for 1963
    I used the Lectric Limited dash harness and engine harness...completely satisfied. Some, also, like M&H Electric. Both made in the USA.
    Leif
    • Joe R.
      • July 31, 1976
      • 4551
      Do whatever you have to do to obtain an M&H wiring harness.
      JR
      • Harry S.
        • July 31, 2002
        • 5330
        Dave, agree with Joe, go with M&H. http://www.wiringharness.com/
        Sometimes Keene has several in stock.
        • Gary J.
          • April 1, 1980
          • 1244
          • Richard G.
            • July 31, 1984
            • 1718
            There are early and late 63 headlight harness. Match to the originals.
            If you need a late 63 headlight harness I have one.
            Don't ask.
            The EL harness I have, for the cowl to the headlights, doesn't have the same wire colors as the one I removed. The 63 has plastic ties (Well mine did anyway) that hold the wiring harness to the header above the lights. The EL harness came with a built in plastic push in tab. This tab was not correct for my car. Show below;
            The wiring colors, for the headlight motors, didn't match my original 63 wiring.
            Replacement and original.
            With the information I have now I would try another vendor besides Electric Limited.
            I have not have any issues with the function of the harness.
            Rick
            • Dave S.
              • August 31, 1992
              • 2926
              Thanks to all. I do have a new headlight harness and dash harness but the engine harness is old and really needs replacing.
              Gary - Your advice is good. All the items you mentioned are out for restoration.
              • Frederick H.
                • August 31, 1983
                • 458
                Richard, I could not find anything in the Judging Manual about differences in the early and late headlight harnesses. I'm sure M&H will have the info but would rather confirm with another NCRS member just to be safe.
                Fred
