I took my 67 for a drive and everything was fine. The next day I went out to start it and got what I would call one click/partial crank. Then nothing. I hooked up a jump battery and still nothing. Quit and charged the battery overnight. Still nothing. Finally got out my VOM and the voltage at the battery was 12.6. Check the voltage at the battery terminal on the solenoid, 12.6.
After research on the forum and elsewhere, I suspected the ignition switch. Tested for voltage on the purple wire at the solenoid and the switch in crank mode and nothing. I bench tested a spare switch I have and then installed it. Nothing.
Then suspecting the wiring connections at the bulkhead, I pulled then, wire brushed and spread all the pins to make sure there is good contact. I had done this about 6 months ago when I was having battery meter issues.
I check continuity and voltage on the red wire. 12+ volts at the horn relay and back of the alternator. 12 volts at the circuit breaker under the dash. Strange was 10 volts on the red wire at the ignition switch. Not sure about that one as according to the wiring diagram the red wire at the ignition switch come from the circuit breaker.
Some other issues that must be related.
Headlights turn on but not the dash lights. Courtesy lights work. Turn signals work. Headlight motors are real slow and I could not get them fully opened. Horns don't honk. I can hear the relay click and maybe some slight horn sound. So I checked the voltage at the horns. When honked I'm getting 2.2-2.5 volts.
Could the horn relay be causing all my problems?
Don
Don
