71 stereo radio has started making a high pitch squeal after playing about 15 minutes with the car running.
if radio volume is turned up it goes away for a few minutes and comes back louder
radio was completely rebuilt and bench tested by tech and working well a year ago. Checking the speakers I get +/- 5 ohms instead of 8 so I know the speakers are an issue. if I turn on the radio with out the car running there is no issue and plays fine over extended time. As soon as the car is started the squeal is back and does not go away. If I turn the car off and play the radio it will continue to squeal.
It is not an alternator noise and has no change in noise with engine rpm. I have tried touching a good ground to the radio, both amplifiers and mounting hardware at the console.
I am wondering if the radio circuitry is compromised having had wrong speakers installed
Open for ideas
Steve
Open for ideas
Steve
