So, after ~ 35 years, we're road worthy! But we have a minor sticky throttle problem. (Brake pedal too, but that is not as exciting, it just leaves the brake lights on...).
It's not an 'absolute' stick, so, for instance, when shifting with one's foot in it a little, it seems 'OK', but if just puttering along, one discovers that a foot off the gas pedal has no effect. One can pull the pedal up, OK, or blip it, mostly returns to normal idle.
So, suggestions? Historically I've not had shielding, putting a bit of a dog leg in the cable.
So we worked on it a bit, had it hanging up and wiggled the bowden cable hither, thither and yon, to no positive effect. We connected the spring to a different 'hole' stretching the spring more, and that cured the problem, but the cure (difficulty modulating the gas, LOL) was worse than the problem. I can see another way, which won't stretch the spring so much, but at the moment I've other things I must do.
