Caliper O Rings between each half - NCRS Discussion Boards
  • Sheldon S.
    • March 1, 1999
    • 482
    Are the little O Rings between the caliber halves the same as what you would get in a O Ring kit as far as compatibility with the fluid. Not referring to size. For some reason after a year I have 2 callipers that one o ring has failed and is leaking now. I have severqal O Ring kits and am pretty sure they will be OK with the fluid but just checking with others on this.
    Sheldon
  • Russ S.
    • April 30, 1982
    • 2163
    Re: Caliper O Rings between each half
    What brake fluid are you using? If new dot 5 read up on the recent posts regarding new dot 5 damaging seals.
    • Sheldon S.
      • March 1, 1999
      • 482
      I used DOT 3 fluid, looks like maybe the edge of the O Ring might have been pinched slightly, also notice little lip on the face that might not have been letting the two half fully seat. I filed the surface flat before reassembly. The second O Ring was perfect.
