Is there anything special about the 4-mounting nuts used to attach the Carter 3461S to the intake manifold (plating, thickness, etc)?
I believe I have the original and correct fuel lines. Tubing chrome plated as are all of the nuts, elbows, etc. There is an 45 degree elbow on the carb that is chrome plated as well which I also assume to be correct. Looking for confirmation as to whether that elbow is supposed to be chrome plated because a fuel line kit I recently picked up had everything correctly plated except that brass elbow.
