GM ignition lock system - Guide Pamplet - NCRS Discussion Boards
  • Jerome P.
    • October 22, 2006
    • 607
    Does anyone recognize this as part of an Owner's packet? If so, what year(s)?
  • Jeffrey S.
    • May 31, 1988
    • 1901
    Re: GM ignition lock system - Guide Pamplet
    Jerry,
    This is a sun visor sleeve for 1969. There were at least 2 versions (I have both) dated 10-2-68: 3964572, which is smaller, and the one you have, 3964573. I'm not sure which was used on Corvette- others may be able to help here. Reproductions are available but real ones that are not ripped off are hard to find. Hope this helps.
    • Jerome P.
      • October 22, 2006
      • 607
      Thanks, Jeff. I looked through the current TIMJG for 1970 - '72 and could not find anything that referenced this pamphlet. Is it safe to conclude this was not part the info delivered with '70 - '72 Corvettes?
        • 15634
        Not with my 1970 #2161
        • Reba W.
          • 938
          We think it was only used in 1969 when the ignition switch moved to the steering column. Note it says, ".. the new ignition system."
