1963 Ashtray Restoration - NCRS Discussion Boards
  • Gerald C.
    • June 30, 1987
    • 1299
    I have an original AAC ashtray that has some rust in the inside bottom. Any thoughts on how I get this rust out and the finish I should put in for judging purposes?
    Jerry
  • Harry S.
    • July 31, 2002
    • 5330
    Re: 1963 Ashtray Restoration
    What ashtray do you have? The one on the left or the right. What month was your car built?
    • Gerald C.
      • June 30, 1987
      • 1299
      The one on the left. My car was built 10/31/62. Just bought it on eBay and it's on its way to me
      • Harry S.
        • July 31, 2002
        • 5330
        That's a good style for your build date.
        Try Naval Jelly on the rust. Since there is rust the flash chrome is gone. Best I can tell from a small survey both style ash trays were used in 63. The single tang was probably from the first supplier and was used at initial production with some of the double tang mixed in. The double tang was much easier to remove to empty the ash tray and at the end of 63 production only the double tang was installed. The single tang was eliminated.
        • Rick A.
          • July 31, 2002
          • 2147
          agree with HArry
          Rick Aleshire
          2016 Ebony C7R Z06 "ROSA"
          • Gerald C.
            • June 30, 1987
            • 1299
            Thanks Harry
            • Alan D.
              • January 1, 2005
              • 2046
              I would also try safest rust (ultraoneusa.com) or Evapo-Rust (com) also see orisonllc.com or orisonmarketing.com
              both of these have a 6ph or better and stop working at ph=7.0
              These leave even paint marks alone. Just another option.
              • Michael M.
                • February 1, 1993
                • 604
                Why don't you just get the ash tray flash chromed?
                • Michael J.
                  • January 27, 2009
                  • 7145
                  How much rust does it have? You want to make sure you don't remove the chrome finish. Sometimes it is just best to take a point deduct for the rust.
                  • Michael G.
                    • November 12, 2008
                    • 2157
                    My car was built a couple of days before yours. The ashtray was similarly rusted and there are no correct new or used ones to be found.
                    I tried everything, rust solvent and lots of other stuff, to try to rescue it, all to no avail, the rust was too deep. Finally, I sanded down the corrosion as smooth as I could get it and painted the bottom with about ten (or more) coats of chromium paint. It looks almost perfect now. (if you stick your face down in it, you might see the paint line. )
                    Fortunately, I don't smoke, 'cause I'm pretty sure a lit cigarette might set all that paint on fire
                    Mike
                    1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
                    1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
                    • Richard G.
                      • July 31, 1984
                      • 1715
                      Late December 62 Car. I have the one on the left also. Single style spring.
