67 427, front spring replacement, no a/c, best source? - NCRS Discussion Boards
  • William B.
    • April 30, 1975
    • 942
    Want to purchase new springs for my 67 427/400 with no a/c, read a lot of info about car not sitting correct with new springs. Can anyone recomend a source for the correct replacement springs?
    • 43281
    Re: 67 427, front spring replacement, no a/c, best source?
    William------
    How do you know that you need new springs? I don't necessarily recommend replacing them just as a matter of routine or just because "they're old".
    • William B.
      • April 30, 1975
      • 942
      Thanks Joe, I usually do not replace springs, but this one is sagging down over the wheel, rear is a little off but that's to be expected. Still need the best source, I am thinking Long island?
        • 43281
        William------
        I think that Long Island would be a good source. Also, Eaton Detroit Spring. Eaton has the GM Restoration Parts license to reproduce the original spring. Of course, as with all GM Restoration Parts, adherence to original specs is always suspect.
        • Daniel S.
          • January 14, 2011
          • 309
          I had very good luck with Detroit Eaton. Car was a '66 L36 with ac. I only did this when NOS GM was not available.
          Dan
            • 43281
            Dan
            Dan------
            The original springs for this application, GM #3888250, are long-discontinued and difficult to find.
            • Daniel S.
              • January 14, 2011
              • 309
              Dan------
              Completely agree...
