65 vs 63 head lights - NCRS Discussion Boards
  • Michael G.
    • November 12, 2008
    • 2157
    I was doing ops on my 65 in preparation for the regional next weekend, when, sure enough an original headlight fogged up, smoked and burned out as looked at it. I guess the physicists are correct when they say that the act of observing something happen changes the outcome...
    In any case, it looks like my Duntov 63 has temporarily become one of those car you flip over in the backyard and strip, so, are 65 headlights the same as 63?
    Mike
    1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
    1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
  • Loren L.
    • April 30, 1976
    • 4104
    Re: 65 vs 63 head lights
    No, and give Thanks.
    • Harry S.
      • July 31, 2002
      • 5330
      Hope this helps..
      • Frank D.
        • December 27, 2007
        • 2703
        I slather clear silicone sealer around the electrodes on the back of my 63 T3 headlights. Not sure if it helps but it may prevent them sucking air and burning out when ignited after a long period of disuse....
        • Bob W.
          • December 1, 1977
          • 802
          Harry, Great post very helpful.
          Bob
          • Michael G.
            • November 12, 2008
            • 2157
            Thanks Harry, the blueprints are too small to see, even for an old body designer, like me. I gather, though, from the date info, that 63 and 65 are the same. If I've interpreted that wrong, please let me know. I found a T3 in my stash, I think its good one. Please take a look and let me know what you think:
            Mike
            • Jack M.
              • March 1, 1991
              • 1181
              This older chart came from Lectric Limited: T3 Bulb Identification Chart.pdf
              • Harry S.
                • July 31, 2002
                • 5330
                Frank, I used the red high heat silicone in the same areas. So far no burnt bulbs.
                • Michael G.
                  • November 12, 2008
                  • 2157
                  I didn't notice the "DOT" marking on that bulb, its a repro. The one below works and (another one from my stash) doesn't have item DOT marking, so I think I'm good to go. Didn't have to violate the 63..
                  Mike
                  • Michael G.
                    • November 12, 2008
                    • 2157
                    Frank, before I button this up, do you have a pic of your silicone job? (re-reading that, I think maybe my wording wasn't the best)
                    Mike
                    • Jeffrey S.
                      • May 31, 1988
                      • 1890
                      Mike,
                      All 1961-'67 headlights are the same (except for the date stamp on back). 1960 low beams internals are a holdover from 1959 (diffuser is a half circle as opposed to full circle in later years but the lens is the same as later years).
                      Jeff
                      • Frank D.
                        • December 27, 2007
                        • 2703
                        I don't have pictures unfortunately - perhaps Harry does ?!
                        I do remember there is not a really 'neat' way to do it though - odd angles and protrusions, best to be a little messy but get good coverage...
                        • Harry S.
                          • July 31, 2002
                          • 5330
                          Here ya go....
                          • Frank D.
                            • December 27, 2007
                            • 2703
                            Yup - that's about as good a job as you can do. I believe in the practice though....my T3s are seldom used but light up every time with no burn outs...
                            • Michael G.
                              • November 12, 2008
                              • 2157
                              Thanks guys, I can handle that, I don't want this one to go up in smoke after sitting on a shelf for a decade or more...
                              Mike
