Gas gauge deflects with turn signal - NCRS Discussion Boards
  • Michael J.
    • January 27, 2009
    • 7167
    I have a problem with my '63's gas gauge. Not sure it is working as it is on full, but when I use the turn signal, it deflects (down) just like the volt gauge does. Anyone have experience with such things? Thanks.
  • Gene M.
    • April 1, 1985
    • 4233
    Re: Gas gauge deflects with turn signal
    Check grounds. Sounds like one circuit is grounding thru the other.
    • Michael J.
      • January 27, 2009
      • 7167
      Thanks, I will check the ground wires first.
      • David H.
        • June 30, 2001
        • 1559
        Mike,
        Check tail light ground. I believe both are common. Does your gas gage deflect when you depress brakes? (same ground)
        Dave
        • Michael J.
          • January 27, 2009
          • 7167
          Thanks David, no, no deflection with the brake lights on.
          • Ed H.
            • November 1, 1999
            • 626
            Mike, while I was restoring my 57 I read on the tech board that if you double ground the fuel sending unit at it's source
            this will preclude the gas gage fluctuation. I used brass end units brass star washers at both ends. I found a location on
            on the rear upper of the frame, ground off to bare metal drilled a hole at that location, used #10 wire and a sheet metal bolt, dialectric grease, put
            all together and no fuel guage fluctuation. Grounding is the most important function of a corvettes electrical system. I used Lectric-limited
            complete wire system and added the grounding touch. Good luck.
            • Michael J.
              • January 27, 2009
              • 7167
              Thanks Ed, I will try that, I am digging into it as I have time. It is odd that the gas gauge deflects with the turn signal and brake light, whether or not the gas gauge fuse is in or out. With the gas gauge fuse in, it reads full and deflects, with the gas gauge fuse out, it reads empty and still deflects. Usually, with the fuse out, it sits at 1/2. I am also thinking the gauge package may be missing a good ground someplace. I do know the black wire from the sending unit is missing, I cannot see it as it enters the plug under the dash, it should be there with an eyelet to screw into the plate under the door light on the driver's side, this is a tanker sending unit. I will have to search around from the sending unit behind the seat to the plug at the gauge package to see what happened to it.
              • Richard G.
                • July 31, 1984
                • 1718
                I would pull the spare and tube and take a look. Great time to check the gauge with an ohm meter.
                Easy enough to get to and the most likely spot to find an issue.
                • Michael J.
                  • January 27, 2009
                  • 7167
                  Fortunately, this is a tanker, so the sending unit is behind the driver's seat. It has three wires coming out as a harness, that then disappears as a wrapped bundle (with the wires from the rear of the car) under the door sill and behind the carpeted kick panel, into a plug that clips on the birdcage. That is the area I am looking now for the ground wire from the sending unit harness.
                  • Richard G.
                    • July 31, 1984
                    • 1718
                    I should have remembered that! (Tanker)
                    Hopefully you will be able to get to the harness connection and check it there.
                      • 6957
                      Hi Mike, I think Gene M. is on the right track, what it sounds like its sourcing your ground to your rear lights because the tank sender ground is open, I would just make up a temporary ground wire long enough to ground the unit, get a couple of alligator clips.
                      • Michael J.
                        • January 27, 2009
                        • 7167
                        Thanks guys, I am making progress. This car was fully restored several years ago, probably by a restorer who was not familiar with tanker sending units. The two wires connected to the back of the gauge are not the two that should be there. One is the switched 12V wire, the other is brown, as it should be, but is a ground wire instead of the wire coming from the sending unit variable resistor. So that explains why it goes to empty when the fuse is out and full when the fuse is in, and deflects with a load like turn signal or brake light. I suspect the brown wire from the sending unit has been crossed with the ground wire. I will get into the sending unit harness from the tank soon and check that all out.
