Carter AFB Accelerator rod bushings - NCRS Discussion Boards
  • John F.
    • March 23, 2008
    • 2408
    I am trying to correct a few point deducts from judging and purchased the bushings from LIC. The white ones came in the package Part #28-47 and the black one were what was on the car. The judges did not think the black ones were correct. Can someone post a picture of what should be correct and laid out? I have the AIM and it shows a bushing and a sleeve. Am I missing something? If so, where can I get the right part? I need one at both ends of the rod.
    • 6941
    Re: Carter AFB Accelerator rod bushings
    John, I think that my 63 bushings are a gray color, and the flat surface of the plastic bushing has a bigger head, I do not think the LI are correct, if no one post a pic I will take one of my 63 later after work tonight. Its amazing what the judges can find, especially when there's little to find.
    • John F.
      • March 23, 2008
      • 2408
      I don't think I have the right bushing or sleeve. Can someone verify?
      • John F.
        • March 23, 2008
        • 2408
        Thanks Ed! I want to see what you have.
        • Bob K.
          • September 28, 2011
          • 36
          John, Call me at 314 843-7545. I'l send you what you need. The black insert is made with a raised outer lip, You have to push it half way thru and it will lock on the lever. Then you insert the white plastic bushing to accept the throttle rod. You will need one for both ends. Bob K
          • John F.
            • March 23, 2008
            • 2408
            I just spoke with Bob Kunz and he has what I need.
            • Joe R.
              • July 31, 1976
              • 4550
              John,
              Here's a pic of what are original and what is not.
              The upper ones are originals and the bottom are replacements.
              The accelerator rod is zinc or cad plated also.
              JR
              • Mike M.
                • May 31, 1974
                • 8382
                the black items were a rubber-like material and what long island sells usually passes. its the WHITE nylon bushings shown from long island that get a deduct because originals were a light yellow color, not snow white. mike
                • John F.
                  • March 23, 2008
                  • 2408
                  Thank you Joe!
                  • Thomas S.
                    • February 7, 2016
                    • 617
                    You can also get these from GM Restoration https://restorationpartssource.com/s...r-details.html
                    LIC's are not correct. Different material used on the "White" pieces. The original ones were translucent not solid white. Also, the holes on the LIC's white pieces are not centered correctly or at least they weren't on the ones I received. Left is correct, note offset hole in LIC. In fairness LIC is a great outfit and 99.9% of the time, their stuff is OK.
                    67 427/400 Lynndale Blue Corvette https://online.flippingbook.com/view/750924569
